no timing mark???
Old Apr 3, 2008 | 07:55 PM
snozz2004's Avatar
snozz2004
Default no timing mark???
hi, i've been building a 1.8 zetec turbo engine & i've fitted 2.0L cams, the only problem i have is the exhaust cam pulley doesn't have a timing mark on it, is there any other way of finding the right timing position?
Old Apr 3, 2008 | 10:24 PM
NATH-RSZT's Avatar
NATH-RSZT
neither of the cams have a timming mark from standard you lock the cams off at the other end with a flat bar, that is tdc
Old Apr 3, 2008 | 10:29 PM
madmack99's Avatar
madmack99
I Love BooST
cant you just mark it where it is with a little bit of paint and do it that way ??
Old Apr 3, 2008 | 11:00 PM
DIORYY's Avatar
DIORYY
do it
Old Apr 4, 2008 | 08:43 PM
snozz2004's Avatar
snozz2004
Cheers mate.
yes i can, but i needed to know where tdc was to do that.
Old Apr 4, 2008 | 10:39 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
don't tighten the pulleys using the flat bar though, as you can break bits off the cam that way!
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
MK Motorsport Matt
75
Nov 15, 2015 11:22 PM
StephenC
Oct 9, 2015 09:33 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
