valvoline vr1 10w 60 semi synthetic engine oil ?
Old Apr 3, 2008 | 11:23 AM
scoooby slayer's Avatar
scoooby slayer
Default valvoline vr1 10w 60 semi synthetic engine oil ?
would this oil be ok in yb ? i run 10w 50 but would like a bit thicker to hold a bit more pressure at idle. does anyone use this in a yb ?
Old Apr 3, 2008 | 11:34 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
I use VR1 in the RB26 in my Chaser. Think its 10W50 innit? Tho id prefer 10W60
Idle pressure is a bit pointless IMO anyhow, its after that you wanna worry.
Old Apr 3, 2008 | 11:50 AM
Dave Henshall's Avatar
Dave Henshall
far too thick IMO....
i used to run castrol rs 10W60 in the escos. after a good blast, sitting at idle at a set of lights the oil pressurte light would flicker on and the oil pressure on the gauage was next to nothing, a small blip on the throttle and it would come up bu the engine did sound like a bag of spanners.
after taking some good advice from on here from oilman, i put in some fully synthetic silkolene 5W40 (too thin i hear you cry!!!) but believe it or not, after the same run, the silkolene held better oil pressure and the engine was much quieter, not only after a run, but from cold aswell. unless i'd seen this with my own eyes i'd have not believed it.
its to do with how the law changed on the marketing of 'fully synthetic' oil, they are now allowed to call some oil fully synthetic even though it has some mineral content in it, there is a % limit that they are allowedto blend in (for cost effectiveness) and still call it fully syn. the silkolene is 100% fully syn, as as such is priced acordingly. amazingly aswell though, since switching to the silkolene, i had to top up my oil less that i used to when running the castrol RS.
Old Apr 3, 2008 | 11:59 AM
TurboShed's Avatar
TurboShed
Cossiemodo
I think most people here would agree that Castrol RS is fit barely for lawnmowers, let alone your YB.
Old Apr 3, 2008 | 12:27 PM
Dave Henshall
in most part true.......
however there is a 100% fully synthetic castrol RS that BMW use, and this is only available from a BMW dealer and is priced accordingly
Old Apr 3, 2008 | 12:30 PM
Azrael's Avatar
Azrael
We had some bad experience of VR1 on Subarus. I woudn't risk it. Motul is the way to go
Old Apr 3, 2008 | 12:34 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Where is Oilman and his immense technical knowledge when you need him??
Old Apr 3, 2008 | 12:36 PM
richm's Avatar
richm
Absolutely totally agree, I've had the very same experience
The Silkolene Pro-x 5/40 maintains hot pressure very well by comparison
Old Apr 3, 2008 | 02:56 PM
The Youth.'s Avatar
The Youth.
I put valvoline synpower 5/40 in my cossie last night used this stuff in my cossies for 11 years now and never had to do a rebuild..must be ok!!
steve
Old Apr 3, 2008 | 03:35 PM
Dave Henshall
steve
thats just as good as the silkolene , ie a real 100% synthetic oil with the corect viscosity .
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
