Warping brakes (not only ford)
Old Apr 3, 2008 | 09:46 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Warping brakes (not only ford)
What's the problem with warping brake discs these days ?
Cossies suffered (still do) from them, evo's suffer too apparently, and, reading stu's post on his M5 purchase, it would appear even top of the range BMW cars suffer from this problem.
I am sure many other cars suffer from this too.
What I don't understand is that in 20 years, nobody's come up with a solution yet !!! Is it a steering geometry / stability problem ? The roads ? Too small a disc setup for the weight of the car ?
Old Apr 3, 2008 | 09:50 AM
Dal_'s Avatar
Dal_
People sitting at lights, junctions with the footbrake on rather than using the handbrake. Nice hot pads on hot discs, what do they think will happen?
Old Apr 3, 2008 | 10:26 AM
AlexF's Avatar
AlexF
Its incorrect running in procedure!!
Alex
Old Apr 3, 2008 | 10:34 AM
frog's Avatar
frog
Alex
Isn't the procedure for running brakes in the same as the one for running engines in... e.g. nobody really knows what's best, but everyone has an opinion ?
Some say they need short sharp bursts of braking in the early days, others say that energetic braking should be avoided for a few hundred miles...
Old Apr 3, 2008 | 03:39 PM
AlexF's Avatar
AlexF
I run cheap disks and race pads on my cars...
My procedure is tired and tested by several people and its never seen a warpped set of disks....
Old Apr 3, 2008 | 03:40 PM
AlexF's Avatar
AlexF
Your only dealing with uneven heat build up...
Its not rocket science, or engine science
Alex
Old Apr 6, 2008 | 07:29 AM
flashpoint's Avatar
flashpoint
As for running in brakes i would say drive normaly.... what ever that is...?
Old Apr 6, 2008 | 07:42 AM
GUZZLER's Avatar
GUZZLER
thats my method for running in engines aswell
take it easy as first, then drive it as a 'normal' person would for a sensible amount of time, as said, most brake problems are caused by to much heat.
Old Apr 6, 2008 | 04:48 PM
jammy86's Avatar
jammy86
I read a good article on the myth of warping brake discs a good while back. As Darenspalmer has pointed out, this is often the cause of the so called "warped disc". There are a few other reasons it can happen too.
As for bedding pads in, there are a few tried and tested methods. The quick method is 50-30 gently 5 times then 70-30 starting gently and working up to aggressive, over 5-10 times, seems to work very well for me. either that or drive normally and go fairly easy on them for 100 miles or so. not 100miles straight down the motorway though, that doesnt count.
JAmes.
Old Apr 6, 2008 | 05:06 PM
Alan_D's Avatar
Alan_D
Mine regularly heat up to the point where they are completely useless and dont work at all. If I'm using them hard all I do is drive say the last 10 miles home cruising and avoiding using the brakes at all. By the time I get home the air has totally cooled them and I can park it straight up...Discs arent warped in the slightest!
So yeah its definetly heating them right up and leaving the car sitting that does it.
borboyous
Aug 22, 2015 11:17 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
