Engine cuts out on 4x4 Sapphire
Old Apr 1, 2008 | 02:57 PM
17-APG's Avatar
17-APG
Default Engine cuts out on 4x4 Sapphire
Hi guys,
I am just new to the forum and intend to spend lots of time going thro the various threads....
I have a 4x4 Sapphire from new in july 1992 and recently it has started to cut out when i floor the throttle.It runs perfectly at idle or even 80 mph on motorways. If I accelerate "gently" it will go right up the rev range but when I floor it the engine just cuts out as if I have turned off ignition (rev counter stll remains at current rev). After a split second it starts again.If I continue holding down the throttle it stops/starts and jumps violently.
Any help will be most greatly appreciated.
Old Apr 2, 2008 | 06:57 AM
bpspa's Avatar
bpspa
I'm no expert but sounds as if its blowing the spark out, have you tried new leads and plugs
Old Apr 2, 2008 | 07:04 AM
I agree with bpspa, that is the first thing I would do, plugs and leads.
Gap at 0.65mm, and use decent plugs and leads like Magnecore, plus a group a coil, just for a bit better spark.
Old Apr 2, 2008 | 10:49 AM
oldford's Avatar
oldford
Could also be the boost limit kicking in.
What boost do you have currently with gently acceleration and what's the reading when you floor the throttle?
Is it chipped or not? When chipped what level of boost are you supposed to have?
Old Apr 2, 2008 | 10:50 AM
17-APG's Avatar
17-APG
Many thanks for this. Will will get new plugs and leads this weekend and fit them. Will let you know how I get on . It seems really odd because I never thought of plugs/ leads as this is not a misfire at all. Its just like I switched the engine off and back on again real quick. That would mimick the exact problem that I have.
Old Apr 2, 2008 | 10:53 AM
17-APG's Avatar
17-APG
It is chipped; stage 1. I put the old chip back in to test with the same result. I do not have facility to check boosts but if leads/ plugs do not sort it out I will turn my attention to boost. Someone else has told me to change the fuel filter but I really do not think it is the filter??
Old Apr 3, 2008 | 06:45 AM
There is a faint possibility it could be the filter, though I don't think so, but if not changed within the last year I would do this anyway, check pump voltage at the same time, under load.
Old Apr 3, 2008 | 08:54 AM
IANS2RST's Avatar
IANS2RST
check the pipes that come from the turbo to the amal valve sounds as if its hitting the boost cut off.
Old Apr 3, 2008 | 10:53 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
got a similar problem on mine, would love to know the answer!
Old Apr 4, 2008 | 08:48 AM
SS1's Avatar
SS1
has your petrol tank got a swirl pot ?? try filling the tank half full..then boot the car see what happens
i only run my car on a half a full tank...as i have no swirl pot in the tank
needs to be upgraded
Old Apr 7, 2008 | 04:19 PM
17-APG's Avatar
17-APG
Guys,
I have fitted the new fuel filter, new plugs (Motorcraft AGPR 902P) and leads and the fault is still there. The engine just stops on the way up. My gut feeling is maybe the boost as Ians2RST and oldford have indicated.
Not knowing too much aboiut the boost can you tell me what to look at? Where is the boost unit anyway? And can I just turn back the boost w/out using a guage just to see if it stops the engine completely cutting out??
Your help is appreciated...
Old Apr 7, 2008 | 06:20 PM
oldford's Avatar
oldford
17-APG do you have a so-called "ämal" valve? This is an electrically controlled brown valve normally placed on the right hand side of the intercooler. It has 3 connections for air hoses and an electrical connection. Disconnect the electrics. Now your engine should run with low boost and should not reach the boost limit. Just try it on the road and see if the engine cuts out. You should feel a substantial loss of power, but this is normal, because the boost is a lot lower now.
Old Apr 8, 2008 | 10:44 AM
17-APG's Avatar
17-APG
Thumbs up
Yes I believe there is oldford. There is a small round plastic valve positioned to the left side of and on top of the intercooler quite close to the actuator ( as you stand and look at engine bay). This valve has a brown centre with a number of air pipes and an electrical connection on top ( from memory maybe 3 point connection). I will remove this and run road test to see what happens at weekend....
Old Apr 8, 2008 | 10:48 AM
17-APG's Avatar
17-APG
Not sure on swirl pot, I dont think so but what I do know is the problem exists whether i have just a few litres in the tank, 50% full or full. I really believe my problem lies with tirbo. The engine just stops under hard acceleration; it doesnt splutter or misfire it's just " lights out" for a second and then fires up again.
jason_nike
Aug 18, 2019 10:53 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Old ford
Jul 31, 2015 06:50 AM
