Indicator problems
Old Mar 31, 2008 | 09:41 PM
Kev read's Avatar
Kev read
Default Indicator problems
My indicators packed up the other day and wondered if there was a way I could check if it is the stalks or if there is a problem somewhere else? My hazards also dont work, but then again they never did. I recently put a diffrent home made dash in, could that have somthing to do with it? Also if it is the stalks, can I get the non-wiper speed adjuster ones to fit?
Thanks
Old Apr 1, 2008 | 07:06 AM
Rolls's Avatar
Rolls
Relay? - Is it clicking?
Old Apr 1, 2008 | 04:35 PM
Kev read's Avatar
Kev read
nothing, completely dead. They still flash when you arm the alarm though
Old Apr 1, 2008 | 05:10 PM
You first need to check for power at the indicator stalk, with ignition on, ther eshould be a LIVE going to the stalk for the indicators, so use a test LIGHT(bulb) so when you prod it they wil try to flash.
The LIVE for the headlights will also be there, so find out which is which first.
I would have a good pressing session with the hazzard switch as this all goes through the hazzard switch contacts, even the normal indicators.
The alarm uses itself to generate a brief supply to flash the indicators, so means nothing.
Old Apr 2, 2008 | 03:00 PM
Aaroncast's Avatar
Aaroncast
---------mines Been Working On And Off For Years!!!!! ---------------
Hazards Are Independant From Indicator System (by Law)the Common Is The Lamps Thats All------- Roo Ta Toot-toot-
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
