ABS On my Saph
Hey guys, I have just fitted some 4 pot AP brakes on my cossy, and am having slight problems. We bled the brakes and now I think that the bloody abs unit is playing up.... AGAIN. I changed it over a few months back after cooking the old one (no heat shield hehe) and just replaced it with a second hand one off ebay.
I'm not sure if it;s ever been right though, but Now after disturbing the brake system, I've got a problem. The brake pedal seems to go flat to the floor with little resistance, and the wheels can still be moved. But check this out.... The abs unit is constantly making a whining sound as soon as you turn the ignition on, and it takes like 1 minute for it to stop. Then as soon as you press the brake pedal, it starts making the noise again. It's very weird. There also seems to be a hissing noise everytime you push the pedal down, almost sounds like an air leak, but I detected this sound is coming from the silver unit over the other side of the engine bay.
Any thoughts guys..... Is it just a dodgy ABS unit causing all this crap.... ? Cheers
Damn old Ford ABS systems, curse them all
Yeh had ignition on when we bled the backs, its strange though the abs unit is making a terrible racket. I will try the old washing up liquid technique to see if i can find a leak, it almost sounds like its trying to presurize but cant becuase it won't hold pressure in the system.
