BMW Problem...I know its not a ford.
Old Mar 29, 2008 | 09:48 AM
jconstant's Avatar
jconstant
Default BMW Problem...I know its not a ford.
The other day i noticed my e36 318i auto developed a squeek when ticking over, i thought easy fix just a bit of white greese behind the pullys and job done....boy was i wrong ...Then yesterday i had trouble starting the car, it would turnover but it struggled to fire up.
I have no idea what it is and it bugging me, when driving today on the m25 it was ok but as i got on to the a406 there was a slight hint of miss fire.
The most concerning thing is that when i was ideling on my driveway just 10 mins ago and it was squeeking away i decided to pull out the dip stick and out went the pressure and the squeek stoped but the idle was still rough. As soon ad the dip sticjk was put back the squeek started again.
Any ideas?
Old Mar 29, 2008 | 04:54 PM
Sounds like a slight air leak somewhere, try squirting easy start around the area to find it, but not too much, it will rev when sucked in.
Old Mar 30, 2008 | 08:23 PM
jconstant's Avatar
jconstant
Also i forgot to mention that there seems to be alot of suction on the dipstick and the oil fillercap.
Old Mar 30, 2008 | 08:54 PM
martinmilne's Avatar
martinmilne
i had one do the same thing at the front of the inlet manifold there is a pipe about 2" long by about 10mm in diamater they perish and muck up all the sensors hope this helps
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
`spotty
Sep 25, 2015 11:41 PM
Kam B
Sep 24, 2015 10:40 AM
