does 94 bt need cat for test
Old Mar 28, 2008 | 11:10 PM
chunky3's Avatar
chunky3
Default does 94 bt need cat for test
as title
Old Mar 28, 2008 | 11:13 PM
KSA-Cossie's Avatar
KSA-Cossie
Not if you run closed loop.
Old Mar 28, 2008 | 11:20 PM
Kelv's Avatar
Kelv
Almost there!
i think anything after september 1992 requires a CAT,
but gladly tell me im wrong if i am.
Old Mar 28, 2008 | 11:28 PM
KSA-Cossie's Avatar
KSA-Cossie
No iirc you're correct m8.
Old Mar 28, 2008 | 11:43 PM
chunky3's Avatar
chunky3
how does everybody get them through with full stainless.is it best to look for a very understanding and helpfull test station
cheers for replies lads
Old Mar 29, 2008 | 07:25 AM
NO CAR OF ANY MAKE OR AGE IS REQUIRED BY MOT OR LAW TO HAVE A CAT.
The problem is the emissions were tightened so much after the "cat" date that most will NOT pass without one, but if it does all is LEGAL, to use car etc.
LPG cossies/cars/4x4's for example do not need cats.
Old Apr 2, 2008 | 03:08 PM
Aaroncast's Avatar
Aaroncast
------------as Above Its All To Do With Emmisions !!!----------
---------- Ive Not Had One On My Escos For Over 7/8 Years -no Problem-------
Dont Need One ----------not Legaly Bound-------
Old Apr 2, 2008 | 03:47 PM
AlexD's Avatar
AlexD
Post Miester !
Closed loop on mine ! better than a 1.0 micra ....lol .!
Old Apr 3, 2008 | 03:46 PM
Dave Henshall's Avatar
Dave Henshall
if you can proove that a car registered after august 1994 has an engine that was registed prior to aug 1992, then the oldest part (ie the engine) is the part that determines what emmisions test it has to pass.... ie, non cat
now where is that reciept for that 2wd saph engine.....
Old Apr 3, 2008 | 04:27 PM
tonyrally's Avatar
tonyrally
passionford god
tabetha u are a very inteligent guy by the sounds ov it. u always have a good efficient answer we shoud have an ask tabetha room lol iv seen them on other forums one i used to go on it had a n ask redhand he was a realy helpfull guy thanks tony
Old Apr 3, 2008 | 10:17 PM
Gordon1's Avatar
Gordon1
thats the way ....
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
