mondeo 4x4
Old Mar 28, 2008 | 10:46 PM
Phil2002's Avatar
Phil2002
Default mondeo 4x4
can anyone please help is the rear diff of a 4x4 mondeo the same as a 4x4 mk6 escort rs2000.
Thanks in advance.
Old Mar 29, 2008 | 12:35 AM
iansoutham's Avatar
iansoutham
OCD Victim
The actual diff casing is listed as the same, but the assembly is listed as different. Probably uses a different ratio.
Old Mar 29, 2008 | 09:51 AM
MarkN's Avatar
MarkN
No - I don't think it is. I believe the group at rs2000-16v.com have looked into this in detail and confirmed that the Mondeo transfer box cannot be used on the Escort.
Old Mar 29, 2008 | 11:54 AM
Phil2002's Avatar
Phil2002
I'm using all mondeo running gear as in gearbox transferebox and diff on a mk6 escort so was woundering if the mondeo diff will physically fit in the rs2000 4x4 rear beam.as mentioned above if the diff casing is the same them am i correct in thinking that it will fit. How about the rear hubs and drive shafts are they the same. Thanks for your help.
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
The Enigma
Sep 29, 2015 10:31 AM
