strange smoke
might sound daft but i was giving my 4x4 saph some beans the other day round a very sharp corner in second gear and when i straightened up there was a puff of reek that came out the drivers side bonnet vent its never happened before but then again i never cane it any help would be great thanks in advance
Gary from Portsmouth had fuel spray over onto the turbo somehow and the smoke came out of that vent... as seen at Ford Fair. Check those fuel seals mate - just in case, I know they are on the other side but the pressures are high so it might squirt over like his did. Cant think of much else on the turbo side as said???
cant be the turbo its a proper ford t34 and its done hardly any miles since fitted about a year ago it doesnt smoke on start up theres never any reek just that one time and thats it
Probably just a bit of oil dripping onto a hot component, ie. turbo or manifold. The very sharp bend, a few drops of oil from somewhere, no major surprise, I've noticed the same myself once or twice.
Didn't get to chat to Gary but yes his was fuel somehow. Fuel rail may have worked loose or seals just perished on the injectors. No pipes appeared loose from what he told me at the time. All worth checking imo - if only for piece of mind eh?
yeah defo mate im getting back onshore today so il be looking at it when im finished with the bird lol cheers for the help
do you have a dump valve ?
back when i had my first cossie i was giving it some right foot action then when i backed off and the dumpvalve went off it misted oil everywhere. Looked like a fine smoke to start with, then realised the oil that cam out of the valve hit the turbo and burnt, hence the smoke
this was obviously without a cold side conversion !
Steve Escos
Oct 1, 2015 06:57 AM
