engine running problems overheating!
Old Mar 23, 2008 | 07:10 PM
JezSierra's Avatar
JezSierra
happy with that
Default engine running problems overheating!
right got an RS Turbo converted cab,as far as i can see standard apart from stainless exhaust system,dirty dump valve,and incar boost controller
anyways,they guy who i had it off had by passed the heater matrix,due to when the converison took place one of the pies tot he heater matrix had been damaged,so i got it home drove fine all the way home with out fault no over heating,(drove it over 14 miles home)took it out the next evening,got stuck in a little traffic and i could see the needle rising up,so was getting very worried by this point,drove it straight home and switched it off,
thought there might have been an air block in the cooling system so ran it up to see if there wat any air trapped,it was just above running temp and the header tank started bubbling up badly and started to over heat badly too,the fan isnt cutting in either
theres no oil/water mix is it the headgasket?failed water pump?cracked cylinderhead?wot should i look for?
is it a big job to do myself?exspensive?
any advice appreciated
cheers Jez
Old Mar 23, 2008 | 07:18 PM
threebarboost's Avatar
threebarboost
then its a fan problem as you stated, check the wiring plugs on the switch, just below the top hose/thermostat housing if it is unplug it and bridge the wires the fan should come on with ign on if it does then you have a faulty temp switch, if it dont come on you need to check the wiring to the fan or maybe the fan its self, i would say the switch 90% of the time.
Old Mar 23, 2008 | 07:27 PM
JezSierra's Avatar
JezSierra
happy with that
its now over heating after like mons of running now though,i will check the wiring and switch 1st thing in the morning
cheers mate
Old Mar 23, 2008 | 08:29 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
try to bridge the multi plug on the fan switch on the thermostat housing and the fan should come on mate!
if they do it the switch, if they dont its poss wiring!
Old Mar 23, 2008 | 08:31 PM
jonnyrsturbo
sounds like the switch to me!!!!!!
Old Mar 23, 2008 | 08:39 PM
JezSierra's Avatar
JezSierra
happy with that
can i make something so i can run the fan permantly?as my old ERST used to suffer bad with over heating too nothin like this though
Old Mar 23, 2008 | 08:46 PM
jonnyrsturbo
there is two connectors half way up the o/s wing if u connect them then it should run constant, or perm bridge the multi plug on the thermo housing....
or put in a switch!!!!!!!
big_Rad
Sep 15, 2017 09:36 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
