alternator belt
Old Mar 22, 2008 | 05:42 PM
RS craig 71's Avatar
RS craig 71
Default alternator belt
how do you change alternator belt on 93 4x4 saff, looks totally different to early ones,many thanks in advance.
Old Mar 22, 2008 | 05:45 PM
KSA-Cossie's Avatar
KSA-Cossie
Don't know m8 but my mechanic had mine done in minutes .
Old Mar 23, 2008 | 08:27 AM
Probably just a serpentine belt, ie MULTI RIBBED FLAT one ?
If so just changed as normal belt making sure to get it in all the grooves when refitting a new one.
Old Mar 23, 2008 | 10:10 AM
RS craig 71
yes it is a long belt, but the earlier ones have tensioner and this doesn,t or i,m just not seeing it ,was thinking maybee you stretch it over pulley,s lol .
Old Mar 24, 2008 | 08:23 AM
There has to be a tensioner, often it is a device like the alternator that is moved to take up slack, but not always.
Old Mar 24, 2008 | 12:55 PM
RS craig 71
cheers tab i.ll have another look at weekend .
Old Mar 24, 2008 | 03:16 PM
IANS2RST's Avatar
IANS2RST
automatic tensioner located just below the alternator above the power steering pump.
all you will need is a 15mm spanner rotate the tensioner clock wise to relieve the tension & pop the belt off
Old Mar 28, 2008 | 07:49 PM
RS craig 71
good stuff many thanks.
Old May 28, 2013 | 02:06 PM
Paul Wooster's Avatar
Paul Wooster
I'm trying to fit my aux belt but the belt seems too small?
I know they should go on tight but when tensioner is fully rotated the belt still has a little way to go.
It's a 94 ford escort Z-Tec without aircon and the belt I was supplied was for my car without AC but all the diagrams I have looked at have one less pulley than my engine??
Confused?
jonfoc
16
Sep 11, 2018 05:35 PM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 18, 2015 04:38 PM
