Starter motor and solenoid
Old Mar 22, 2008 | 05:28 PM
leeadams's Avatar
leeadams
Default Starter motor and solenoid
Just a quick one, am I right in believing that you can not just change the sloenoid on a 2wd cossie, as it is part of the starter motor?
Thanks
Old Mar 22, 2008 | 08:51 PM
jon@work's Avatar
jon@work
I doubt you can buy just the solenoid by itself, but you certainly can take them off the starter and change them.
Old Mar 23, 2008 | 08:13 AM
You can buy just the solenoid, and as above says, it is held on with two through screws with philips/pozi drive heads.
The unfortunate bit is they are BOSCH solenoids so stick anyway, although LUK(lucas, etc) copy most BOSCH stuff.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
