Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Desmodromic Valve Operation
Old Mar 22, 2008 | 06:46 AM
TimC's Avatar
TimC
Default Desmodromic Valve Operation
After speaking with a friend yesterday about Moto GP we ended up in a conversation about desmo valve operation. Iv had a look on Wiki but I think the info on how the system operates is a bit vague, so would really appreciate if somebody can explain it better, possibly with a video clip of it in operation?
Thankyou in advance.
Old Mar 22, 2008 | 06:48 AM
TimC's Avatar
TimC
Somehow quickly managed to find this video clip
Old Mar 23, 2008 | 08:23 AM
DESMO or DESMODROMIC merely means that the cam/s are GEAR DRIVEN, ie do nit employ belts, chains, just a set of gears, operating (normal) POPPET VALVES, although some have in the past operated ASPIN VALVES.
Old Mar 23, 2008 | 09:35 AM
Mark V8's Avatar
Mark V8
The Ducati desmo uses a cam belt to drive the cams, the main difference is that it uses no valve springs and relies on a second lobe to shut the valve meaning no valve float at high revs.
Mark
Old Mar 23, 2008 | 12:54 PM
testastretta999's Avatar
testastretta999
Default desmo
Desmo are belt driven. Opening rocker and closing rocker for each valve. System used to control valve bounce and better control for valve, ie being able to close later than spring type set up.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
