Turbo help!!!!!!!!
Old Mar 21, 2008 | 05:49 PM
martysport's Avatar
martysport
Default Turbo help!!!!!!!!
Having a bit of trouble
I have a chance of getting some turbo stuff for my 16V I4 conversion thats in my Sierra.
I need some info before deciding to take the plunge.
At the moment I'm using a stock RS2000 ECU which is working fantastic N/A.
I was 'thinking' would it be possible to use a FRST ECU? I know that engine is 1.6 and mine is 2.0 but the RS2K injectors flow approx 25cc more than the FRST ones so a step in the right direction.
If that idea is stupid I'd like to keep the RS2K ECU and use some sort of 5th injector+controller.
What are my options? where to buy from and how much? easy to set up?
Anyway, some piccys of the gear. Going by the piccys I'd need a downpipe, intercooler and some induction piping?
Any advice would be great BTW compression ratio is standard-ish (10.44:1)
I havn't bought the stuff yet, I need advice before a final yes.
Nearly forgot, turbo specs. OK for normal compression?
I know next to nowt about the black arts
T04 " O " T3/T4 V Band
.70 A/R TURBINE HOUSING
.GREAT FOR RAPID SPOOL!
Turbine Wheel:
Exducer: 2.54"
Mayor : 2.89"
Compressor Wheel:
Exducer: 2.23"
Mayor : 3.31"
Turbine Housing:
70 " DIVIDED TANG FLANGE "
Old Mar 21, 2008 | 06:45 PM
e36_dan's Avatar
e36_dan
bit of advice do not use xs power i used one of their turbo kits on my civic and the turbo lasted all of a week, i wasnt runnin silly boost either
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
