Pinto tips and tricks
Old Mar 19, 2008 | 11:07 PM
lvx's Avatar
lvx
Default Pinto tips and tricks
Hi
I'm fitting a 2.0 pinto into my mk2 1600 sport. I'm down in South Africa so I can't order performance parts from the UK without great expense. Can somebody point me to articles or give some tips on factory parts that I can use to mod the Pinto? I know for instance that one can use pistons from the VW 1800 water cooled engine to do a 2.1 conversion (we don't have the 2.9 ford motor here). I've also heard that 44mm Toyota valves (I'm not sure which model) can be used in the Pinto head. All advice appreciated, thanx!
Old Mar 20, 2008 | 07:34 AM
The normal trick is to use 2.8 V6 pistons, for around 2085cc.
Carbs can be pretty much anything, from 32/36 to 40DFI.
Burtons do a good range, so could at least get ideas from there.
Old Mar 27, 2008 | 07:17 AM
NAKRS's Avatar
NAKRS
Smile Pinto Rocks
IVE GOT FRIENDS RUNNING SIDEDRAFTS, THROTTLE BODIES AND TURBO SETUPS USING THE PINTO motor CALL ME I WILL HOOK YOU UP
0737930044 Nak
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
steff19
Escort Range
Sep 9, 2015 10:14 PM
