Starting Probs On Mondeo Td?
Old Mar 18, 2008 | 08:44 PM
andyrh's Avatar
andyrh
Default Starting Probs On Mondeo Td?
I seem to have developed a starting problem on my 97 mondeo turbo diesel.
It only occurs from stone cold, it cranks and cranks and after depressing the accelerator it finally comes to life after pushing out a load of unburnt diesel through the exhaust.
I have changed the glow plugs, glow plug relay and fuel filter but all of that still has not rectified it...if anyone has any other ideas it would be greatly appreciated!
Old Mar 20, 2008 | 09:54 PM
coss1e2000's Avatar
coss1e2000
Is it the 1.8 diesel? If so could be camshaft sensor
Old Mar 20, 2008 | 10:09 PM
tonyrally's Avatar
tonyrally
passionford god
if it is a 1.8 td they have a comon prob with the fuel filter housing does the prime go hard after 5-6 presses? thanks tony
Old Mar 21, 2008 | 07:27 AM
As said diaphragm holes in the filter head are common, allowing air in.
Have you checked for POWER at the glow plugs as may have a electrical problem(broken wire), have you drained the water off lately from the filter head ?, try some MILLERS diesel cleaner awsomely good stuff, as is BIO DIESEL which has a massive cleaning action, so much so that they can only stick 5% bio in normal diesel.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Alun Gregory
Sep 6, 2015 09:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
