Fuel pump wont prime
Old Mar 18, 2008 | 03:41 PM
mikee_rs's Avatar
mikee_rs
Default Fuel pump wont prime
My fez has been off the road since beginning of sept cos i blew up the gearbox. i fitted a new 1 2day and after checking everything over i connected the battery and turn the key to crank over the engine (i discconted the coilpack to stop it starting) to get some oil presure in it and the fuel pumped prime up as normal.
then.......... i connected the coilpack to run the engine and when i went to start it ther pump didnt prime up, ive checked all the fuses in the fuse box and they all seem fine. havent got a clue what why it isnt priming as everything seems ok. i havent been anywhere near the fuel tank or any of its wiring when putting in the box, the only wires i disturbed around the battery and the starter motor
any idea?? was looking forward to finishing the car today but now im fucked off
its a fiesta rs turbo with a zetec turbo engine btw
Old Mar 18, 2008 | 03:43 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
you dont have the same feed to the coil as you do the fuel pump do you?
Old Mar 18, 2008 | 03:48 PM
mikee_rs's Avatar
mikee_rs
not to sure to be honest
electrics isnt my strongest point
Old Mar 20, 2008 | 10:01 PM
coss1e2000's Avatar
coss1e2000
Fuel cut off switch?
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
