Spring rates for the front of my 205....views?
Hello mate, you want to look through www.merlinmotorsport.co.uk
they stock every length and lbs option known to man (almost).
As for desired choices dependant on usage and personal preference really.
The Escort racers like the RS1600i touring cars of the mid eighties Brooklyn / Longman etc used springs roughly in the region of 350lbs front and 1000lbs on the rear depending on the track they were racing on.
For track day cars which are used on the road i reckon around 275 / 300 front and 600 ish on the rear which is more or less what the MK2 Fiesta boys use as well. A bit hard on the back end but good for the track.
Like i say trial and error until your happy.
Im going for 320 and 600 on mine for this year.
£20 ish for a spring its not to dear to try options out
http://www.merlinmotorsport.co.uk/CO...130/index.html
here are the options..
Spikey check out this site for some ideas etc on set ups...
stage 3 - highlights suspension / handling setup.
http://www.balancemotorsport.co.uk/m...ry=Project+Car
click on the respective options in the table chart.
paul was my passenger and mentioned they seem a little soft and the nose dips a bit
and the other guys said i should be running 280-300 :S
and bigger anti roll bar on the rear
i want to try hard springs and see what i think, so the nose dont dip when i brake hard and turn in fast
plus they cheap enough for springs....hint hint
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
