RS brakes on a 1.8 Zetec??
Old Mar 16, 2008 | 09:32 PM
Alan_D's Avatar
Alan_D
Default RS brakes on a 1.8 Zetec??
Hi all, I used to have a 1.8 zetec focus and always wondered if it was possible to stick RS calipers and discs on it...Bearing in mind the rear are drums as standard on the 1.8? Is it do-able, whats involved?
Cheers, Alan
Old Mar 16, 2008 | 10:36 PM
wirralphil's Avatar
wirralphil
By what you have posted you mean you want rear discs?
Old Mar 16, 2008 | 11:01 PM
Alan_D's Avatar
Alan_D
Was thinking both front and rears from an RS. But yeah, how would you go about converting drums to calipers and discs.
Old Mar 17, 2008 | 06:13 AM
Just a case of changing bits over.
Old Mar 30, 2008 | 03:59 PM
tomsimes's Avatar
tomsimes
I've literally just had a friend ask me about the same question, about fitting RS front brakes to a 1.8.
I know he doesn't care about the rear drums, but are the front a bolt-on job, or are custom mounting brackets needed for the callipers?
Old Mar 30, 2008 | 04:12 PM
pani_k's Avatar
pani_k
PassionFORD Member
rs calipers, rs driveshafts, rs suspension, rs discs and pads, rs cv joints, rs knuckles and hubs.
by no means a straight swap and expensive as hell.
you are much better off doing an ST170 brake conversion
Old Mar 30, 2008 | 05:11 PM
mark_h's Avatar
mark_h
Ford Freak
it can be done , but at the very least youll need st170 hubs and brakets making for the calipers, its not a straight swap even if you fit the hubs , because then you need the suspension aswell shafts etc a said above , far better off just going for the st170 conversion .
Old Mar 30, 2008 | 10:24 PM
pdfbt40's Avatar
pdfbt40
Actually I'm afraid both previous are slightly incorrect.
Yes,you have to change the knuckle/hub, but if you fit the ST170 there is no need to change driveshafts, suspension, etc. - the same as a complete ST170 300mm conversion.
You need a 5mm spacer behind the RS Disc to give clearance from the lower arm/ball joint. Then a conversion plate for the calliper and RS brake hose.
All described in a How To in Focus Owners Forum over a year ago.
Martin
Old Apr 2, 2008 | 08:07 PM
mark_h's Avatar
mark_h
Ford Freak
i ment youd need to change the shafts and suspension if you went for the rs set up using rs hubs.
talon1
Sep 15, 2015 10:27 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
