S1 Turbo hoses, help needed
Old Mar 16, 2008 | 07:03 PM
Curt's Avatar
Curt
Question S1 Turbo hoses, help needed
Hi
Need some some help please with turbo hoses on a series 1
I need to know where the two smaller hoses on turbo in picture go to thanks
Old Mar 17, 2008 | 12:11 AM
g1234's Avatar
g1234
you should have 1 off actuator and 1 off turbo going to amal valve the other one on turbo never seen that before should not need it
Old Mar 17, 2008 | 01:36 PM
Curt's Avatar
Curt
Thanks for reply
So the other one I just leave open or blank it off?
The problem I have is car is not boosting so I looked at turbo connections and found this hose just open (larger one in picture).
The other hose (smaller one in picture goes to amal valve and actuator via a t piece, is this also correct?
Old Mar 17, 2008 | 11:16 PM
g1234's Avatar
g1234
the big one blank off
1 from turbo goes to amal valve (3)
actuator to amal valve (2)
othe amal valve meterin head (1)
if you go to car passanger wing look at amal valve and imagine numbering 1-3 from left to right thats what the numbers in brackets are for if you get the jist of it
no t piece needed
jaimesdna
Aug 25, 2015 06:59 AM
muz
Aug 16, 2015 12:57 PM
Escortdriver1
Aug 13, 2015 05:55 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
col93saphcos
Aug 7, 2015 03:21 PM
