NO SPARK
Old Oct 20, 2004 | 10:20 AM
1.9s1's Avatar
1.9s1
Default NO SPARK
Hello everybody.
Can anyone please help? Im having trouble with my series 1
Everything was all fine until one morning i got in it and no start
So first things first check for fuel: yep got that so check for spark: Nope no spark so off to ford garage and replace: coil, plugs, leads, dizzy cap, and arm. still no spark . any ideas? this is driving me nuts.
Thanks for any advice.
Cheers mark
Old Oct 20, 2004 | 10:28 AM
escort mk1's Avatar
escort mk1
Have you got 12v feed to coil should come for ignition switch?
Old Oct 20, 2004 | 10:41 AM
1.9s1's Avatar
1.9s1
with ignition on volt meter reads 12v between black wire(+ side of coil) and earth but nothing off green wire (- side) not much of an expert with car electrics
Old Oct 20, 2004 | 10:56 AM
escort mk1's Avatar
escort mk1
Ignition module ok?
Old Oct 20, 2004 | 11:11 AM
1.9s1's Avatar
1.9s1
Where do i find the module and how can i test it?
Old Oct 20, 2004 | 11:34 AM
escort mk1's Avatar
escort mk1
The electronic control for the ignition system. The module receives a signal from a magnetic pickup or Hall effect sensor in the distributor. The module uses this signal to open and close the ground circuit to the ignition coil to fire the spark plugs. The ignition module itself may be located inside the distributor (GM and some imports), on the distributor housing (some Ford applications) or in the engine compartment. Some modules also control timing advance and retard. If a module goes bad, it usually goes completely dead. The engine won't run because there's no trigger voltage to the ignition coil.
Hope this helps
Old Oct 21, 2004 | 11:18 AM
1.9s1's Avatar
1.9s1
Thanks for your help mate. I've been playing with this for about a week now with no joy so i think the time has finally come to pull the ke jetronic junk out and replace it with efi
Old Oct 21, 2004 | 11:39 AM
Rick's Avatar
Rick
lol, dont give up.
Check u have voltage at the relevant pins on the ecu plug - haynes manual will tell u.
Old Oct 23, 2004 | 09:39 AM
1.9s1's Avatar
1.9s1
Thanks for the advice Rick, Ive just checked at ecu & its all fine
I've now convinced the wife that i need efi so im about to start pulling things apart.
Old Oct 23, 2004 | 09:47 AM
boost mad's Avatar
boost mad
i dont no if it is the same on a S1 but on the side of the dizzy the is a little box which is an ignition amplifier, this went on my 1.6 cvh fiesta. it might be worth looking into that
Old Oct 23, 2004 | 10:03 AM
James Raby's Avatar
James Raby
Maybe the distributor is dead???
Sure they don't have ignition module either...
Old Oct 23, 2004 | 10:13 AM
EIL132's Avatar
EIL132
Hall effect
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
