Can someone explain big end and little end?
Old Oct 20, 2004 | 01:22 AM
kevsrs's Avatar
kevsrs
Default Can someone explain big end and little end?
A mate went to the garage and they said 'oh your big end's away' but we're not too sure what big end and little end mean and what exactly is wrong.
Any info appreciated
Old Oct 20, 2004 | 01:32 AM
digita1dragon's Avatar
digita1dragon
im fairly sure it refers to the end of the crank, at a pure guess i would say pulley end (bearing) but i guess its 50/50
Old Oct 20, 2004 | 02:22 AM
NUTS RuS's Avatar
NUTS RuS
Big ends are refering to the bearing shells around the crank.
The little ends are refering to the bearing shells around the piston.
With poor maintanance and irregular oil changes these bearing shells can wear out, there is then movement in the con rod against the crank causing the knocking noise you here. Usually the only effective solution is either replace the crank and bearing shells or have the crank re ground and fit a slightly bigger shells in.
HTH
Old Oct 20, 2004 | 02:28 AM
kevsrs's Avatar
kevsrs
HTH
That is perfect Rus, exactly what i needed to know, cheers
Indyrs
Dec 4, 2022 12:39 PM
JK12
33
Apr 26, 2021 12:09 PM
SMILER258
Sep 28, 2015 09:04 AM
rsstav
Sep 7, 2015 04:43 AM
hopper350
Sep 4, 2015 12:53 AM
