What offset do I need to cover 330mm 6 pots
Old Mar 10, 2008 | 03:21 PM
jemis's Avatar
jemis
Default What offset do I need to cover 330mm 6 pots
What offset do I need on the wheels to clear 330mm 6 pot wilwoods.
My current wheels are 17" with a 37 offset and they don't go on, I'm thinking about going for 18's but do I need a smaller offset like 33 as I have the chance of some cheapish but they have an offset of 38.
If 33 offset is used with 18's will it cause any clearance broblems with the wheel arches etc, the car is lowered by 30mm and I would use 215/35 tyres.
N
Old Mar 10, 2008 | 03:29 PM
jemis's Avatar
jemis
It is a 4x4 sapphire if it makes any difference.
Old Mar 10, 2008 | 04:57 PM
Ridgey's Avatar
Ridgey
Surely all you need is some spacers, dependant upon what wheels you have. But a 5mm spacer will take you to 33 off set which should be OK.
Don't see the point going to 18" wheels ??
Old Mar 10, 2008 | 06:06 PM
jemis's Avatar
jemis
I've had bad experience in the past using spacers, causing vibration etc, so trying to avoid them if possible.
Old Mar 10, 2008 | 07:03 PM
charlie luciano's Avatar
charlie luciano
Use Eilbach hub centric spacers you won't get no problems
Luciano
Old Mar 11, 2008 | 12:11 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Luciano
Who supplies these? And how much?
Old Mar 11, 2008 | 12:18 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
got my h&r hub centric jobbies from chris flint aka "cossymad" on here
Old Mar 11, 2008 | 12:20 PM
pete mcrash
p.s u'll probably need longer wheel studs aswell...........chris will sort them also
Old Mar 12, 2008 | 09:33 AM
Damocos's Avatar
Damocos
Some wheels will have more clearance than others, i know some of the OZ wheels have some deep clearance on the spokes, apart from that it will be a case of measuring the caliper to hub space and then going from there. On mine i got 335mm six pot hi-specs and some 8x18 Fox rs5's et35 and they clear no problem
Old Mar 12, 2008 | 10:23 AM
dojj's Avatar
dojj
Resident Wrestling Legend
speak to martin "reyland"
i know he sells the comp mo stuff and can get them ordered in specific offsets if you need them and can probably tell you what you need
the other way is to find out what size spacer you will need to get your wheels to fit and then get a wheel with that offset
Old Mar 12, 2008 | 10:24 AM
charlie luciano
Judging by your sig I would hazard a guess and say your car is 2wd, 2wd & 4x4 are a different kettle of fish when it comes to fitting big stoppers, ie the 4x4 is a right pain in the harris,
Luciano
Old Mar 12, 2008 | 12:49 PM
dojj's Avatar
dojj
it's the 8mm worth of greater offset that's the fucker
Old Mar 12, 2008 | 02:45 PM
pete mcrash
as said above 2wd and 4x4 are different.....my wheels fit on a 2wd with the same brakes as mine,but i had to get spacers.......the bells are a different fit/shape
Old Mar 12, 2008 | 06:40 PM
jemis's Avatar
jemis
Hi
Mine is a 4x4 and I would need huge spacers as the spokes curve in a lot, I measured with washers on the studs and at about 12mm they were still catching, if they were 18's or the spokes were flat would probs get away with 6mm but as is the wheels will have to be replaced.
I would love comp mo's but don't really have that sort of money to spend at the minute so I'm looking for something more suitable secondhand.
Mark RS
Mar 5, 2021 06:08 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
