fuel pump relay
Old Mar 9, 2008 | 08:53 PM
rst-g's Avatar
rst-g
ZETEC TURBO
Default fuel pump relay
does your fuel pump have to be on a relay or can you just have it on a switch on/off?
Old Mar 9, 2008 | 09:08 PM
Maki's Avatar
Maki
You will melt the switch... that's why the relays are there
Old Mar 10, 2008 | 07:06 AM
You can get switches heavy enough for this, but as said relay is easier.
Old Mar 10, 2008 | 04:17 PM
Mr.T's Avatar
Mr.T
You wont melt the switch.It all depends on what switch you buy. But most of them wont melt. So yes it can be. I am going to do it. The best one is one of those "nos" switches. They are good and can handle the current. Cos it isnt much.
Old Mar 10, 2008 | 07:13 PM
Any DC current IS a lot, and a LOT harder on switches than AC current.
Old Mar 10, 2008 | 10:07 PM
Aaroncast's Avatar
Aaroncast
>>>>>>>They are good and can handle the current.<<< MR JeroentjeRS
YOU HAVE JUST ANSWERED YOUR OWN REPLY MATE!!!- IF YOU WAS RIGHT NO CARS WOULD USE RELAYS!!!!!!!!------------------ IF IT USES A RELAY -USE A RELAY!!!
Old Mar 10, 2008 | 10:14 PM
Mr.T's Avatar
Mr.T
Didn't say that mate. It would be stupid to use a on off switch in a factory car would it? The guy asked if it has to be. Awnser is yes and no. They use relays on fog light these days. But it wasnt always like this was it? So yes it is better to use a relay cos its std like this. No reason to remove it. Then again if you don't have one in a cross car or something like that. A switch can be used. So i didnt say don't use the relay cos a switch is better. Read before you post something
Old Mar 11, 2008 | 01:47 PM
The POINT of WHY they use a RELAY is due to COST, pure and simple, a RELAY is CHEAPER than a SWITCH THAT IS HEAVY ENOUGH to carry the same current.
Relays cannot be used in some circuits(not cars) due to NOISE they create electrically.
POWER STATIONS, still use KNIFE SWITCHES, these carry MILLIONS OF AMPS, the sort you see in old black and white FRANKENSTEIN FILMS, they spark like buggery when switching, but on a car it is due to cost nothing esle.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
