Crank position sensor
Old Mar 9, 2008 | 08:16 PM
cos4x4cos's Avatar
cos4x4cos
Default Crank position sensor
Hi, i have just had my crank pulley changed and i was wondering if there is a set distance between the pulley and the sensor. Is it that sensitive that you need a set gap? thanks
Old Mar 9, 2008 | 10:20 PM
THE RADMAN's Avatar
THE RADMAN
yes you do, cant remember what it is but ill have a look tomorrow if nobody else has got back to you
Old Mar 9, 2008 | 11:32 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Gap needs to set between 0.6 - 1.0mm
Old Mar 10, 2008 | 07:01 AM
As said 0.6mm to 1.0mm.
BUT check it on ALL FOUR LUGS, as one may be a little damaged and if set to close for the others could get hit,
They will operate way over gapped or under gapped, as it only needs to disturb electric field.
Old Mar 10, 2008 | 08:56 PM
cos4x4cos's Avatar
cos4x4cos
Thanks very much for the info.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
