ARP olt problem
Old Mar 8, 2008 | 04:58 PM
woolford's Avatar
woolford
Default ARP olt problem
just bought some arp rod bolts for a 2.0l black top engine that im building into a zetec turbo they don't fit even though they are for these does anyone know why???
Thanks
Old Mar 8, 2008 | 05:56 PM
Aaroncast's Avatar
Aaroncast
Exclamation
How Do You Mean?? To Long? Wrong Thread?----------- What???????
Like Saying My Car Wont Start And Not Saying Which Vehicle!!!
Old Mar 9, 2008 | 06:49 PM
woolford's Avatar
woolford
there from a focus... there 9mm... the problem is they go in the first half of the of the first half of bearing(if that makes since)but then the thread gets stuck plus i also tried to screw it in the second part of the rod but the thread is too big...
HELP
Old Mar 10, 2008 | 05:53 AM
anodised's Avatar
anodised
if you have a silver top zetec the bolts are only 8mm
Old Mar 10, 2008 | 11:44 AM
drsrst2zvh's Avatar
drsrst2zvh
As above wrong mm thread i had this oonce before but matt lewis sorted me out swapped em for the other set if you need to buy another set hes the man to get in touch with.
Old Mar 10, 2008 | 09:59 PM
Red16's Avatar
Red16
some conrods actually need to have the holes remed out to suit ARP rod bolts
Old Mar 11, 2008 | 09:37 AM
woolford's Avatar
woolford
how do you do this or is it wise to get someone else to do it for me???
Old Mar 12, 2008 | 10:10 AM
Red16's Avatar
Red16
Drop them off at any machine shop and it should only cost buttons to have it done.
Basically reaming is a process which slightly enlarges a pre-existing hole to a tightly toleranced diameter.
Below is a pic of a reamer
Old Mar 13, 2008 | 07:09 AM
coswurv's Avatar
coswurv
simple amswer for you take one of the original bolts and measure it with a pair of callipers and see what size it is then measure the arp, as for reaming ive built loads of theses zetec's from silver top, black top, st170 internals and none have ever needed reaming.
Old Mar 13, 2008 | 07:15 AM
Gooey's Avatar
Gooey
Just had this problem, 9mm ones will be going on ebay and I ve just ordereda 8mm set
Old Mar 14, 2008 | 12:08 PM
Red16's Avatar
Red16
iirc it tells you about the possibility of the caps needing reaming in the burton catalogue.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
Russ Payne
Sep 25, 2015 08:29 PM
