DIZZYLESS COSSIE's
Old Mar 8, 2008 | 11:34 AM
Default DIZZYLESS COSSIE's
For all those running dizzyless cossie's where do you mount your phase sensor ?
Thanks
Old Mar 8, 2008 | 11:50 AM
KSA-Cossie's Avatar
KSA-Cossie
Still in it's factory position m8.
Old Mar 8, 2008 | 12:03 PM
silky16v's Avatar
silky16v
Get on That!
Thanks
surely some1 with your wealth of knownledge should know that?
Old Mar 8, 2008 | 12:18 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I think he means when the dizzy assembly is removed...you can cap it off and have the sensor somewhere else IIRC some people have done it this way. They must have as I've seen the blanking things for sale before to remove the dizzy assembly.
Dan
Old Mar 8, 2008 | 12:44 PM
I was just after IDEA's really, I favour on the cam cover myself, but so long as it's out of the way, obviously anywhere that rotates at 1/2 crank speed, so that just leaves cam/pulleys, and jackshaft pulley.
Got to get organised as so many new bits on the new ecu, even got a friendly form of AL, plus TC, LC etc etc and CL with EGT, direct coilpack, so no amps to go wrong either, going to also take off the troublesome ISCV and use a different one mounted elsewhere.
Old Mar 9, 2008 | 11:34 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
https://passionford.com/forum/technical-essay-archives/117489-fitting-a-cam-cover-mounted-phase-sensor-to-a-yb.html
Old Mar 10, 2008 | 06:58 AM
Thanks B9KOS, that is exactly what I needed, as have seen others here, the sensor looks like a ZETEC one.
I would do it myself if I trusted myself machining, but a bit like watching a horror film with me on a lathe, still thinking of getting one though!!
Old Mar 10, 2008 | 05:10 PM
Bomber's Avatar
Bomber
It is a Zetec sensor.
Old Mar 10, 2008 | 07:11 PM
I thought I recognised it from my mondy auto that I rebuilt.
Old Mar 11, 2008 | 05:36 PM
sailorbob's Avatar
sailorbob
If you are wanting to run a phase sensor why not just leave the distributor in place but place a blank cap on it? However, if you are changing the phase sensor to a CID sensor then you could use the small turbo sensor.
Old Mar 11, 2008 | 09:23 PM
I am going to run mine off the aux shaft pulley wheel, as it's easier, but thanks all for replies.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
