16i gearbox
Old Mar 7, 2008 | 11:57 PM
ShandzS1's Avatar
ShandzS1
Default 16i gearbox
Whats the difference from normal mk3 box? slipper? ratios?
Old Mar 8, 2008 | 11:56 AM
JesseT's Avatar
JesseT
Nothing really...
Old Mar 8, 2008 | 12:10 PM
bluescortcossie's Avatar
bluescortcossie
fifth gear ratio was different (0.83:1 compared to 0.76:1)
no LSD if i remember right
Old Mar 9, 2008 | 01:04 PM
ShandzS1's Avatar
ShandzS1
So reduces top end speed? but quicker through the gears?
Old Mar 9, 2008 | 02:52 PM
XR2's Avatar
XR2
There were five different ratios available for 5th gear. Most common was the mentioned 0.83, means the ratio is closer to 4th than on standard gearbox. Final drive was the same like the carb'd XR3 and the S2 RST had. No LDS, but a hole in the bottom of the bellhousing for the cps
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
