Saff electric sunroof
Old Mar 6, 2008 | 09:13 PM
Saaamon's Avatar
Saaamon
Default Saff electric sunroof
Can anyone tell me whats needed for the conversion and how hard it is to do? It the wiring fairly sample for an auto sparkie to carry out?
Thanks simon
Old Mar 7, 2008 | 05:44 PM
The wiring is a doddle to carry out DIY, as can use interior light feed.
The motor will need to come off a granada(mk3) or scorpio as the sierra ones that were electric to start with have a different number of splines so motor won't fit, unless you wanted to change whole sunroff cassete case over, the electric switch panel bit from sierra fits, but the reinforcing bracket holding the panel is the hard bit to get, but could always make one.
Old Mar 8, 2008 | 11:22 AM
Saaamon's Avatar
Saaamon
cheers for that mate
Old Mar 8, 2008 | 11:31 AM
You can also make them ONE TOUCH open/close, slide shut/slide open!!
Old Mar 8, 2008 | 03:31 PM
cossied's Avatar
cossied
Default roof
tell me more. thanks
Old Mar 8, 2008 | 03:57 PM
Just use a one touch window timer from something like a mondeo, I put four of these on my windows in me sapph, just makes it feel a bit more modern!!
Old Mar 8, 2008 | 09:16 PM
nuttynil's Avatar
nuttynil
RS nutta
im into the one touch sunroof good idea mondeo timer
Old Mar 9, 2008 | 07:10 AM
If you pull off the bracket bit that holds the timer and solder wires on there is enough space to hide them around the rear of the armresty bit underneath as that is where I put my 4 for the windows.
Old Mar 10, 2008 | 07:10 PM
MarkN's Avatar
MarkN
Don't use the interior light wiring to feed the sun roof. Its only designed to carry enough amps for a light - not an electric sunroof motor. If you run that many amps through it it could melt.
The best bet is to run a new wire up from the electric window circuit which is deisgned to take a similar load.
Old Mar 10, 2008 | 11:44 PM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
MarkN is 100% correct on that, Never use the light circuit as it cannot handle the large amps drawn from the motor.
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
Kam B
Sep 24, 2015 10:40 AM
