Cosworth Over Fueling
Old Mar 6, 2008 | 08:54 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
Default Cosworth Over Fueling
I Having A Problem With A 4x4 Cosworth Basically Was A Non Runner, I Have
Checked And Rectified Spark At Plugs, Swapped Map Sensor, Swapped Crank Sensor And Tried Another Fuel Pressure Regulator
I Managed To Get It Started But There Is Serious Over Fuelling Black Smoke.
When I Un-plug The Injectors & Start The Engine It Runs Good For 2-3 Secs
So Tried Injectors I Know Were Just Serviced And Ecu For Same But No Difference. If I Reduce Fuel Pressure Regulator Pressure To Below 1 Bar It Runs And Idles Much Better But Still Over Fuelling (black Smoke)
Any Suggestions Please
P.S. I HAVE RENEWED COOLANT SENSOR & CHECKED WIRING AND THERE IS NO DIFFERENCE
Old Mar 6, 2008 | 10:01 PM
velocity's Avatar
velocity
first thing put fuel pressure back to the correct setting.then change ecu water temp sensor,( also known to give over fueling problems) located under inlet manafold on the l/h side of the head at the back. it has a big connetor unlike the gauge sensor which is close by. see if this helps
Old Mar 7, 2008 | 12:06 AM
CRAIG HAYTER
will try that tommorow thanks for taking time to help me cheeRS
Old Mar 29, 2009 | 07:46 PM
stickertone's Avatar
stickertone
Default sensor
did this cure it???
Old Mar 30, 2009 | 01:26 AM
CRAIG HAYTER
i was a burnt valvethats just an excuse for me to get the engine out and detail it cheeRS for helping
SmudgerByName
52
Jul 28, 2016 06:14 PM
Russ Hill
Aug 31, 2015 06:44 PM
jc1989rs
Aug 30, 2015 06:32 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
