saff cos fuel pump
Hi guys, fitted a new uprated fuel pump on my 4x4 saff and it came with an adapter for the pipe from the tank, Prob i have is that it keeps leaking slightly.
Tried a new clip on it but its still weeping a bit, the adapter is a bit smaller than the orig one on old pump.
But i also had to cut the pipe length down a bit so the pump sat in the carrier right.
Anyone had similar probs or am i just unlucky, gunna try new pipe this w end should be fun as av half a tank of petrol lol.
Cheers steve.
Cheers steve.
also the old pipe might of lost some of it's elasticity due to old age and then stretched when you pulled old fitting out plus it could of left stretch marks on the inside which the fuel is using to sip through
Yeah fitted new copper washer between pump and adapter, Cut about an inch off old pipe to get pump in rite position as adapter stuck out further from pump.
Bought new pipe yesterday and when i got home to change it, it seems to have sealed itself lol, so hope thats it.
Thanks for the replys, regards steve
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
