zetec into sierra
Old Mar 1, 2008 | 03:59 PM
rapidonion's Avatar
rapidonion
Question zetec into sierra
does anybody know what engine mounts would be needed to fit a 2.0 zetec into a saph cossie rep that im building also what gearbox can i use will the starter cause me any probs?
also has any body ever turbo'd the 2.3 or 2.0 i4 out of the scorpio as im also giving this consideration as it would be easyer to fit in the bay i know the 200sx manifold can be addapted for the engine to run turbo'd
cheers all
Old Mar 1, 2008 | 05:00 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
oh yes the starter motor would cause problems, mines had part of the gearbox hacked out, and an adjustable bracket ot fit the starter, nightmare to mesh properly. My advise is to get a brand new one, cause you dont ever want to be taking it off. When i swapped the engine in mine, i got the engine and box swapped, out and in in a day, and 4 days to get the starter motor on!
Old Mar 1, 2008 | 06:05 PM
rapidonion's Avatar
rapidonion
could always push start it every time though lol
Old Mar 14, 2008 | 11:59 PM
Phyco's Avatar
Phyco
it is possible to fit a zetec into a sierra, you can either youse a mt75 box or a type 9. the mt75 would be ablet to handle a bit more power and abuse. i dont no what clutch you would have to use with either though.
The l4 engines can and have been turboed in the past. Turbo Technics used to produce turbo kits for the l4 engine back in the late 80's- early 90's. i was lucky enough to find somone selling one of these turbo kits about a year ago. it includes a cast turbo manifold, t25 turbo, fith injector elbow and fith injector. i have since changed the fith injector driver that i am running to an aquamist one with is more controllable. i also had to use a universal intercooler from forger motorsport. i hope this helps and if you have any other questions i will try and answer them.
Here are a couple of pics of my turbo kit fitted.
Old Mar 15, 2008 | 11:39 PM
Wardy257's Avatar
Wardy257
Use the starter from a DOHC I4 auto. Engien mounts and sump from a CVH Sierra.
Old Apr 13, 2009 | 08:52 AM
rsdarrel's Avatar
rsdarrel
how does the starter motor attach then as on the zetec engine it on the inlet side of the engine but on the gearbox ts on the other thanks
Old Aug 21, 2010 | 09:16 PM
scott-78's Avatar
scott-78
good question.. Im about to do the same conversion. Does anyone know? I shall use a 1.8 zetec flywheel on a 2 litre silvertop. Not sure what clutch to use and what starter mods if any needed??
RB26DETT
Feb 5, 2022 01:54 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
