zetec turbo inlet???
Old Feb 29, 2008 | 09:10 PM
Phil2002's Avatar
Phil2002
Default zetec turbo inlet???
Hi can any one help i'm building a custom in let for my zetec turbo using the bottom half of a rover turbo in let will a cozzie or a fiesta turbo fuel rail line up with the rover one so that the injectors are in line.
Old Mar 1, 2008 | 05:25 AM
JesseT's Avatar
JesseT
If you are using the Rover lower half, it has the fuel rails and such included, so why the question? The Cossie rail has a much larger injector spacing and the fiesta injectors are at an angle.
Old Mar 1, 2008 | 12:24 PM
Phil2002's Avatar
Phil2002
Answered my own question 2.0 8v vauxhall calibra fuel rail will fit managed to get one from the breakers this morning. I need to change the fuel rail to compensate for the plenum i am making the standard rover gets in the way. the injectors are about 93mm apart.
Old Mar 1, 2008 | 11:05 PM
Red16's Avatar
Red16
just use the rover rail modified to fit the fiesta turbo fuel pressure regulator, all you need to do is drill and tap 2 holes in the rail.
Old Mar 2, 2008 | 11:04 AM
Phil2002's Avatar
Phil2002
the problem is not the fpr i'm using an adjustable aftermarket one. The rover rail physically wont fit as the ends get in the way of the plenum/throttle body i'm using. the vauxhall one will work a treat.
thanks
robnock
21
May 13, 2019 05:29 PM
mrknifey
Aug 30, 2015 11:48 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
