Witch alignment for a fast road Escos
Old Feb 28, 2008 | 02:57 PM
Spotmatic's Avatar
Spotmatic
Default Witch alignment for a fast road Escos
Hello,
I have fitted new brakes and new wheels to my Escos, Now it's time to get the car aligned correct.
The car is used for fast road (curved roads) driving in the weekends and once in the month for a trip to (and ofcourse ON) the Nordschleife. It's not a daily driver.
The suspention still is original and will stay original for a while. The wheels are 18" and the brakes come from AP.
What camber, caster, toe-in/ toe-out do you advise?
Regards,
Mark
Old Feb 28, 2008 | 04:13 PM
Dave Henshall's Avatar
Dave Henshall
only ajustment on a facotory setup is front toe.
set to toing in 1mm overall (0.5 each side) - as the bushes flex under aceleration they deflect to 0 (assuming they are ok and not fooked) which will give a nice neatral feel thet wont tramline too much - like if you set it at 0 to start with as the deflection when accelerating casues it to toe out and pull when you get on white lines etc
Old Feb 29, 2008 | 08:45 PM
ECOS95's Avatar
ECOS95
As Dave has said 0.5mm toe in, had mine set to this & it does feel much better.
Old Mar 1, 2008 | 06:58 PM
Spotmatic's Avatar
Spotmatic
Okay, thanks. I will try so.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
mk22door
23
Oct 2, 2015 10:06 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
AJC
Oct 1, 2015 06:47 PM
