gearbox rebuild s2
how hard is it to rebuild one im pritty good at machnical work but never done one, iv done more or less everything else but have't atemted a box
the thing is i ran it low on box oil and it wooing in every gear, i think the bearings are on there way out it only does it when the clutch isn't pressed
and the other thing it when it's cold the gears are stiff ish like the oil is thick syrup but its fine soon as iv done a mile or 2, any idea what that could be?
any advice would be great
thanks chris
thanks chris
i would put a smilly at the end but i cant find them
sorted
goto User CP > edit options > Message Editor Interface then change to Enhanced interface
now you will have the smilies back
thanks for that i wouldn't have had a clue other wise
Mc5506
Oct 5, 2015 09:57 PM
