heater blower
Old Feb 27, 2008 | 09:42 PM
jst-200's Avatar
jst-200
Default heater blower
Hi all.
I got st200, on w plate. Got problem with heater blower.
As soon as ignition turned on, heaters blow at max.
Cannot turn off, cannot adjust temp.
Just started out of the blue for no apparent reason.
Slightly confused !!!!
Any suggestions very welcome.
Old Feb 28, 2008 | 02:51 AM
bluescortcossie's Avatar
bluescortcossie
has it got the climate pack ? i cant remember (or be bothered to look) if the st200 has climate control as standard
if so its probably the controller for the climate control
if not the blowers on full is probably the resistor pack and wires melted , this is a common fault on mondys and ford released a revised version of the pack and wires , they are situated in the passenger footwell behind the glovebox to the right , easy job to change when you find it !
Old Feb 28, 2008 | 09:01 AM
bookwyse's Avatar
bookwyse
Probably the actual SATC unit in the dash. These are getting prone to failing now the cars are getting on a bit.
I have a spare one sat here that you can have for Ł45. A lot better than Ford's Ł380 quid!!!!!!!!!!!
Jeff
Old Feb 28, 2008 | 06:22 PM
jst-200's Avatar
jst-200
Thanks for the reply mate. Will have a look and let you know.
Old Feb 28, 2008 | 06:25 PM
jst-200's Avatar
jst-200
Cheers bookwyse. Will check it out. Keep it sitting there for me and i`ll get back to you.
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
