ofac efi diagnostics
Old Feb 26, 2008 | 10:36 AM
base190380's Avatar
base190380
Default ofac efi diagnostics
hello, does anyone know if its possible to get a tester for diagnosing faults with a fiesta ofac rs turbo management system and if so where? was hoping to find something that could plug into the piggy back port of ofac ecu? i have this annoying fuelling issue that i cant seem to get sorted for months now!
Old Feb 26, 2008 | 12:43 PM
sailorbob's Avatar
sailorbob
There is a 3 pin connector in the engine bay that is used for reading the error codes. To use this you can make yourself a reader. e.g. a simple LED reader http://www.fordscorpio.co.uk/star.htm or more complicated text display reader http://homepage.ntlworld.com/a.harby2/ggpfcrpg.html Commercial stuff ranges from simple LED readers e.g. http://www.drapertools-online.com/b2...pp_skmno=68082 up to more expensive stuff like the Syke Pickavant ACR2 and upwards.
Old Feb 26, 2008 | 01:35 PM
base190380's Avatar
base190380
excellent advice many thanks, has anyone used these 3 pin single led type readers, ie like the draper one? are they any good.
I was going to get one to try on my 1989 1.6 efi orion which has now been converted to ofac rs turbo efi engine from fiesta rs.
where would the plug be in the engine bay?
Old Feb 27, 2008 | 09:18 AM
sailorbob's Avatar
sailorbob
The LED types can be a pain as you have to count the number of flashes, not so bad on a 2 digit like the RS has but sometimes you lose count
I think the plug is on the offside inner wing, between battery and suspension tower.
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
