i wouldnt know stage 2 but i think diff between them is diff size compressor housing stage 3 isnt too laggy at all it gets going just after 2500k and can hold 20psi with ease
you will need remove the comp housing and measure the inducer and exducer diameters of the comp wheel, and calculate it to get the trim, which is a very easy calculation
