rev counter going crazy on saph
Old Feb 24, 2008 | 09:06 AM
akamob's Avatar
akamob
Default rev counter going crazy on saph
Just been out for a spin in my saph and when i put my foot down in 2nd 3rd or 4th the rev counter gets to about 3500rpm and ther goes crazy, it goes right of the clock bouncy about.the car is standard except for a filter and exhaust. Help
Old Feb 24, 2008 | 09:13 AM
pee vee's Avatar
pee vee
4x4 saph i spose?
If so, its most likely the multi-plugs on the bulkhead, just above the engine,
dry them out and make sure they are all clean and connecting with each other nicely.
thats the place i would start
Old Feb 24, 2008 | 09:27 AM
akamob's Avatar
akamob
yep it is a 4x4
Old Feb 24, 2008 | 04:36 PM
If not it could be the rev counter itself, it is only a voltmetre, with a different scale.
Old Feb 25, 2008 | 09:00 AM
Ryan's Avatar
Ryan
take it to TTD, not sure how far they are from you?
Old Feb 25, 2008 | 03:24 PM
akamob's Avatar
akamob
thanks for the replys,
Had a look at the connection everything looks ok nothing was wet, going out to try it now.
What you mean t.t.d over in spain, there too far and too expensive mate.
Old Mar 21, 2008 | 05:15 PM
RS craig 71's Avatar
RS craig 71
my 4x4 does it every so often as said above, multi plugs clean with electrical spray not wd40 should really do away with plugs and solder together.
Old Mar 21, 2008 | 05:17 PM
RS craig 71
my 4x4 does it every so often, as said above multi plugs clean with electrical spray not wd40 should really do away with plugs and solder together.
tankybaby66
Feb 6, 2016 02:24 PM
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
