Coilpack rev counter...erst
Old Feb 23, 2008 | 10:30 PM
rstdave's Avatar
rstdave
Default Coilpack rev counter...erst
Runnin omex 600 management for a while now but never managed to get the rev counter working properly! Tried loads of different things but nothin seems to work......anyone know where i'm going wrong???? It's a 1990 erst on omex 600 management/coilpacks. Tried adjusting the different cranktooth patterns in the ecu settings and running a wire from the coilpack directly to the rev counter but only get half revs. Someone else must have had the same problem lol!!
Old Feb 23, 2008 | 10:48 PM
sexr3i's Avatar
sexr3i
isn't it
efi 3i clock should fix it.
Old Feb 23, 2008 | 11:01 PM
rstdave's Avatar
rstdave
Funnily enough that's what me and a mate were sayin tonight lol......tryin to find one's gonna be a bloody nightmare tho i'd imagine, as well as the mileage bein out as well....!!! U reckon there's no way of using the clocks i've got?!
Old Feb 24, 2008 | 05:27 AM
JesseT's Avatar
JesseT
You can probably set one of the ecu pins to act as tach out.
Old Feb 24, 2008 | 07:42 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Tach off a mondeo will fit iirc. You'll have to do a little chopping and soldering but shouldn't take more than an hour
Old Feb 24, 2008 | 08:16 AM
pee vee's Avatar
pee vee
the new omex 600 (as RSTDAVE is using) does have a seperate tach-out on the ECU.
but cant seem to get it to work even when the settings for it in the ECU have been changed to every different type!
Old Feb 24, 2008 | 09:25 AM
JesseT's Avatar
JesseT
If the tach don't read anything with the OMEX tach out, you might need a bit of inductive load to distort the signal for the orginal rev counter. There must be something on the OMEX manual about how to connect it to OEM rev counters as it's supposed to be a proper ecu.
Old Feb 24, 2008 | 07:17 PM
sexr3i's Avatar
sexr3i
isn't it
You don't need to change the entire clockpad, just the rev counter. Normally that kind of stuff on ebay as new old stock.
Old Feb 24, 2008 | 09:35 PM
rstdave's Avatar
rstdave
Thanks for the replies guys....looks like an efi rev counter and playin with the ecu settings should sort it with any luck!! I have spoken to omex who sent me somethin to wire in line with the tacho output, a capacitor i think it was but didn't seem to work...hence why i've bin at a bit of a loss with it lol!!
Old Feb 25, 2008 | 05:13 PM
SafeChav's Avatar
SafeChav
Pin 11 of the EDIS is meant to be the easiest way but when i wired Chunt69's car for EFI i was damned if i could get that to work.
Another way is to use a simple diode network across both of the coil packs negatives and then connect it to your rev counter signal wire.
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
bigluke200
14
Sep 2, 2015 10:35 PM
cozzy jeff
Aug 14, 2015 05:46 PM
