what should i replace ??
Old Feb 23, 2008 | 06:29 PM
B1G_RST's Avatar
B1G_RST
Default what should i replace ??
doing the rings and pistons on my rst,
gona order the parts i need on monday, using burton power i think ??
cant aford forge ect so standard rings pistons are going back in,(heads off and bores are in excelent nick)
gona order the fowoling,
rings
pistons
headbolts
head gasket
sump gasket,,
should i get new shells and conrod bolts ?
oh and btw the water pump tensioner and belt hav jst been replaced and been used for around 3miles top haha,
Old Feb 23, 2008 | 06:36 PM
turbo.jon's Avatar
turbo.jon
I would get new shells and conrod bolts would get some arp rod bolts there about Ł70 though i think...
Old Feb 23, 2008 | 06:47 PM
juffer's Avatar
juffer
i would buy the head set imo. you may aswelkl change all the gaskets while its off to eliminate airleaks. If it leaks then it will have to be took apart again
Old Feb 23, 2008 | 06:52 PM
JesseT's Avatar
JesseT
Big end bearigs, IMO.
Old Feb 23, 2008 | 07:40 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
you missed off a timing belt!
Old Feb 23, 2008 | 09:30 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
see below
Old Feb 23, 2008 | 09:34 PM
SWITCHBLADE
all gaskets, bearings and conrod bolts and head bolts (preferably arp). also if you dont know the condition of the oil pump id replace that aswell as its the heart and soul of your engine, if that fails, all your money is down the pan.
while your at it and the heads off you may as well change the stem seals, also id get the rubber gaskets for the sump and rocker cover and id also get a new thermostat and 2 x oil filters and all the lubricants too while your ordering coz obviously youll be running it in and then doing an oil change.
if you want to be really thorough replace any nuts and bolts youve undone too which might of been your rocker bolts, sump bolts and manifold studs and nuts.
dave.
Old Feb 23, 2008 | 09:56 PM
JamboRS's Avatar
JamboRS
focus rs 1672
why you changing the pistons?are they melted,det marks?
no need to if not required
Old Feb 24, 2008 | 05:02 PM
B1G_RST's Avatar
B1G_RST
pistons look fine but thot itl b best to replace, but looks like im gona have to take th engine out n get the bores done as they hav a very small lip where the rings hav stopped,
any1 no if i can take the block out without and leave gearbox in ?
looks very tight haha
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
