Dipped beam not working???
Old Oct 17, 2004 | 09:50 PM
Hartyboy's Avatar
Hartyboy
Default Dipped beam not working???
Is there a relay for dipped beam on the S2 as its stopped working and the fuses are ok???
Old Oct 17, 2004 | 09:58 PM
tommyt's Avatar
tommyt
i had the same prob on the main beam had to play around with the brown and white relay in the right hand side of fuse box it turn all the lights on and off dont no if that will help
Old Oct 17, 2004 | 10:04 PM
AKRS1's Avatar
AKRS1
had this problem on my orion efi once turn out a small white relay burnt out
Old Oct 18, 2004 | 01:34 PM
JimmyFlo's Avatar
JimmyFlo
Default re: dipped beam
just had this prob on mine. I was corrosion of the wires under the fuse box
Old Oct 18, 2004 | 04:25 PM
Hartyboy's Avatar
Hartyboy
Sorted now thanks it was a white relay in the back of the fuse box which had burnt out!!!
malkiemac3579
Jul 14, 2017 12:10 PM
Oct 9, 2015 07:38 PM
Bosch
Aug 23, 2015 12:31 PM
col93saphcos
Aug 7, 2015 03:21 PM
