Mondeo td gearbox fault
Old Feb 22, 2008 | 09:40 PM
Rsailor's Avatar
Rsailor
Default Mondeo td gearbox fault
Right I'm not a newbie when it comes to engines but gearbox's are something that I haven't had much experence with.
I have a mk2 97 plate mondeo 1.8td estate.
I'll list the faults with it and tell me what you think.
Engine will start sounds great.
You have to press the clutch to start it or it will turn really slowly like it's trying to turn the main shaft.
It is really hard to get into gear. It feels like the gearbox has locked up as I can take the handbrake off and try and push it and it will not move.
There is no 5th or reverse gear.
The gear selector feels sloppy and excessive play.
The clutch pedal feels soft.
If anyone lives near Newton Abbot in Devon this would help.
I think,
1 - Gearbox fault.
2 - Gear selector
3 - pressure plate , hydraulic clutch
Old Feb 23, 2008 | 07:36 AM
Seized bearing in gearbox,
Old Feb 23, 2008 | 11:56 AM
Rsailor's Avatar
Rsailor
Thanks tabetha.
Does any one have the allignment tool to relocate the subframe or know where I can get
one?
I've never had to replace the subframe on a mondeo before.
I know that if I screw up, the car will handle like a pig.
Old Feb 23, 2008 | 04:55 PM
You don't need one.
Just use insulating tape, wrapped around the bolt until it is a snug fit in the subframe hole, insert bolt until it is flush, wind up tape gets squashed out of the way, doing no harm.
Old Feb 23, 2008 | 11:26 PM
Rsailor's Avatar
Rsailor
Cheers for that!
Now that is help!
Cheers Carl
Old Feb 24, 2008 | 04:41 PM
Anything to save money, I'm a tight git!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
The Enigma
Sep 29, 2015 10:31 AM
