Engine swap!
Old Feb 21, 2008 | 04:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Engine swap!
Whats the easiest way to fit my new S2 Engine and gearbox?
Drop the engine and gearbox out the bottom and put the new one in?
Or drop the gearbox first and lift the engine out the top?
I'm thinking out the bottom!
Any opinions or experiences welcome!
Thanks!
Old Feb 21, 2008 | 04:48 PM
Noisy Boy's Avatar
Noisy Boy
unless you take the anti rol bar out and other crap in the way your best bet is top
Old Feb 21, 2008 | 04:57 PM
picky775's Avatar
picky775
I found it easier taking mine out from the bottom but remember the front will have to be on good ramps or good high axle stands.
Old Feb 21, 2008 | 05:00 PM
sortedsaff's Avatar
sortedsaff
just done mine last weekend . straight out the top all together . easy peasey
Old Feb 22, 2008 | 03:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I'll be hiring a engine hoist but also have access to a lift, so it can all come out the top together yeah?
Also I want to set the fuelling and timing up so i can drive it to my tuners (16 miles away) any advice?
Thanks!
Old Feb 23, 2008 | 10:20 AM
SafeChav's Avatar
SafeChav
I fitted my engine in through the top and in my personal opinion it was a right ball ache, its a tight old squeeze manouvering the engine and box round past the brake servo whilst avoiding the strut top on the opposite side of the bay.
If its easy for you to get the car in the air then out the bottom is what i would do, the engine would of been fitted below from the factory, and since when have production lines employed a more than necessarily complicated method
Old Feb 23, 2008 | 10:31 AM
diesel's Avatar
diesel
i would say either way is just as hard as each other. when i did mine 3 times me and my mate did it with a scaff bar. if you got a hoist it will be a piece of piss, is the one your putting in allright coz when i puit 1 in it was fcuked
Old Feb 23, 2008 | 01:55 PM
RAT8OY's Avatar
RAT8OY
Out the bottom, done hundreds over the years and far less chance of scratching paint etc. Dont forget as above, the antiroll bar has to come of but you have to virtually remove it anyway to get the driveshafts out, only takes 5 mins.
My opinion anyway.
Old Feb 23, 2008 | 11:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Think i'll go with out the bottom then!
Its a fully rebuilt engine, with ported and polished head, piper BP285T2 and lifters, and a vernier (everything else is standard).
Just trying to find a gearbox now, mines sloppy as fuck!
Any suggestions about setting the timing to get it up the my tuners? Didnt come with a dizzy so am fitting mine, should i just twist it until it runs a smoothly as i can get it to? (the cam belt and vernier are already where they need to be cos it's just been run in)
Old Feb 25, 2008 | 04:34 PM
SafeChav's Avatar
SafeChav
Set the static timing as per a factory car and drive the car sensibly up there, its a far safer bet than twisting the dizzy and relying on your own judgement.
Old Feb 25, 2008 | 07:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Fair play mate, i'll do that!
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
