egr
Old Feb 21, 2008 | 12:14 PM
orion turbo's Avatar
orion turbo
Default egr
on my mk5 rs 2000 iv been thinking off removint the egr system i was just wondering what are the benifits off doing this and is it an easy job
Old Feb 21, 2008 | 01:49 PM
I did it on a 95 mondeo.
Points to watch, some but not all ecu's will go into LOS mode if lecky part is disconnected(differential pressure sensor).
It gives you a lot better access around the engine, not found a downside yet.
It is put on to help the cruise emissions as they run so lean it puts up the NOX dramatically when you go above a certain temp in the combustion chamber, so EGR was used to effect a cooling of these temps to below the critical point.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
CossieRich
30
Sep 8, 2015 10:08 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
