replacing turbo t3 oil seals only
as above just need to get the oil seals replaced, is this a diy job as ive seen them on ebay or is it got to go in for repair? I live in glasgow area anyone know where to go with out getting robbed left right and centre?
Basically car is going perfect but just chuffs out smoke only when on high boost during a gearchange, not whilst under hard acceleration.
Touch and go just replacing the seals. You can only really assess the damage once you have the turbo in pieces, and being as standard ones have wet floating bearings, once something starts to wear it can cause a lot of irrepairable damage.
You're probably best of getting an exchange unit as its not the easiest thing to do either.
big_Rad
Sep 15, 2017 09:36 AM
st220kyle
16
Aug 14, 2015 06:13 AM
