mondeo remote tail gate
Old Feb 18, 2008 | 04:58 PM
Cossy Mike's Avatar
Cossy Mike
Default mondeo remote tail gate
Hello,
my Mondeo mk3 tailgate has a mind of it's own. When I start the car up the tailgate releases then at random after that even whilst driving. I have taken the private lock situated on the hatch off and checked and cleaned it and it is working fine. I can only assume it has something to do with a module of some type under the drivers footwell. Any ideas anyone I am becoming really frustrated!!!
Thank you!!
The button on the dash does not work. Could this be the fault? What is it meant to do? doe sit work the same as the fob, press twice within 3 seconds.
Old Feb 18, 2008 | 08:43 PM
Cossy Mike's Avatar
Cossy Mike
up up^^^^ anyone???
Old Feb 19, 2008 | 07:48 AM
Cossy Mike's Avatar
Cossy Mike
anyone???
Old Feb 19, 2008 | 07:29 PM
Cossy Mike's Avatar
Cossy Mike
Am I the only one in here??
Helllllllllllooooooooooooooooooooooooooo....
Some pls help!!
Old Feb 20, 2008 | 03:52 AM
Cossy Mike's Avatar
Cossy Mike
What do you have to do to get an aswer in here?
I have always found an answer on other sites.......
Old Feb 20, 2008 | 05:26 AM
grcossie's Avatar
grcossie
It`s probably the switch on the tailgate. It comes water innside it, and the problem is there. Sometimes it dosen`t work at all. I have changed many of them
Old Feb 20, 2008 | 10:24 AM
stevecossy's Avatar
stevecossy
The button on the dash should be working 2 mate, its so ya can open boot if sat in car and it should just be a press once jobbie but not when engine is running for safety.
Maybe it is the switch whats thrown a wobbler, try new 1 buddy.
Good luck and sorry for slow reply thought it would of been answeared quick.
Regards steve.
Old Feb 20, 2008 | 12:36 PM
Cossy Mike's Avatar
Cossy Mike
Is the microswitch available from Ford? just the switch with two slim wires or do I have to buy the full casing and rubber?
Thanks
Old Feb 20, 2008 | 01:22 PM
grcossie's Avatar
grcossie
It`s two types of this, one you get only microswitch, the other one, you got the hole casing. It depends on production code of the car
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
