Yep or there is a mondeo setup with the same size calipers just the mounting holes are slightly smaller and need to be drilled out but you will probably find the mondeo ones alot cheaper than the cossies for obvious reasons. Also you will need a spacer to centralise the caliper on the disc probably about 4mm.
