knife edging and tuftridning crank ??
Old Feb 18, 2008 | 02:56 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Default knife edging and tuftridning crank ??
wanting this dont to my zetec crank .
anyone had it done - know where and how much ?
also will they lighten it , or am i better having the machine shop do that with my rods n pistons ??
also can it be polished if its been tuftrided ?
what options do i have ?
thanks beef
Old Feb 18, 2008 | 06:41 PM
-beefy-'s Avatar
-beefy-
anyone ??
Old Feb 18, 2008 | 10:48 PM
Canada1's Avatar
Canada1
Tuftriding is a process used for steel crankshafts. Since the steel crankshaft is much softer than cast iron, tuftriding was used to harden the
crankshaft journals. Porsche used this process in most of thier engines.
Nitriding and heat treating was also used with steel crankshafts.
Since the Zetec crankshaft is cast iron, it already has sufficiently hard journals.
Old Feb 20, 2008 | 11:59 AM
-beefy-'s Avatar
-beefy-
but can i get it knife edged and balanced then ???
Old Feb 20, 2008 | 01:26 PM
Canada1's Avatar
Canada1
Knife edging a crankshaft depends on the intended use.
If the application is a racing one where RPM is well above 6,000 for extended periods, and every last HP found (or not lost)is important, then it may make sense.
In a street driven application it is a waste of money.
Old Feb 20, 2008 | 02:38 PM
rsdan123's Avatar
rsdan123
i had my xr2i cvh crank knife edged, it cost me Ł470 to get the crank knife edged and balanced + head skim + a flywheel skim... other then the head skim i think it was a waste of money!
Old Feb 20, 2008 | 02:39 PM
rsdan123's Avatar
rsdan123
still have the crank if any one is intrested send me a PM
Old Feb 20, 2008 | 10:17 PM
-beefy-'s Avatar
-beefy-
so not worth it then peeps ?
what about polishing ??
or is there anything else worth doing to the crank ??
its 2.1 fast road application ,
Old Feb 20, 2008 | 10:33 PM
mark-rst's Avatar
mark-rst
get it balanced with the flywheel clutch and front pulley...
also get your rods and pistons balanced as well
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
22
Sep 24, 2015 08:14 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
